rystjohn
Lots of preventive maintenance and upgrades. LED light bar, lifted 2”, AWD.
Included: 2 rear bench seats, 4 mounted winter studded tires, full size spare, tow hitch & wiring, amp & sub.
Cons: needs catalytic converter replaced. Oil leak from timing cover.
Cracked windshield - not in drivers direct view. Wiper motor sometimes goes too fast. Sometimes pass. door auto lock is “sticky.”
Used as an adventure & camper van. Not using as much anymore and need a commuter instead.
I love this van but I just don't use it like it begs to be used, and to be completely transparent a friend is selling their Tacoma and I've always wanted one....so this is going to fund that.
Maintenance history since purchase:
@ 175k miles / mid 2019:
- Replaced ALL bulbs w/ LED (except headlight & taillight)
- Electronic flasher relay
- Fuel filter
- Fuel pump assembly
- AVS window covers & hood deflector
- Floor cupholder
- New battery
- 2" lift from Journeys Offroad
- Add-a-leaf in the rear
- KYB mono max struts
- rear axle bump stops
- poly body mounts & 10.9 grade bolts
- pcv valve
- oil pressure sensor
- new motor mounts (from Anchor)
- t-stat
- radiator cap
- NAPA upper control arm bushings
- CV seals (inner)
- Mevotech ttx upper balljoints
- Mevotech ttx lower balljoints
- Moog swaybar bushings
- Moog swaybar links
- Lower radiator hose
- Upper radiator hose
- oil cooler lines
- front differential fluid
- relay rod
- Mevotech inner & outer tierods & adjusters
- Moog idler arms
- Passenger side axle seal
- Radiator & coolant
- Timing cover
- Oil pan gasket
- water pump
- v belt
- belt tensioner
- idler pulley
- radiator fan
- radiator fan clutch
- wheel bearings & seals (rear)
- wheel hub assemblies (front)
- harmonic balancer
- Mass Airflow Sensor
- heater valve
@ 207k / Late 2023, Early 2024
- Thermostat
- Front rotors & pads
- Coolant
- window motor (driver)
- blower motor & relay
- new fuel filter
- new cap & rotor
Very likely more things that I've forgotten to mention. I have tons of receipts and a box of spare parts, fluids, etc.
- Fuel filter
- Floor cupholder
- New battery
- pcv valve
- t-stat
- radiator cap
- CV seals (inner)
- oil cooler lines
- relay rod
- Moog idler arms
- Timing cover
- Oil pan gasket
- water pump
- v belt
- belt tensioner
- idler pulley
- radiator fan
- harmonic balancer
- heater valve
- Thermostat
- Coolant
- new fuel filter
- new cap & rotor
