FWC Hawk owner
We have loved our 2015 FWC Hawk but our lives are taking us in a different direction so we have decided to sell it. It is very, very clean and has almost every option you can think of, plus A/C, camper dolly, generator, and an air jack to help put the top up. A 2025 Hawk with Side Dinette with no options would cost more than this. Available now in Long Beach, CA.
Please email: ssperling1 "at" verizon.net (separated to avoid having email address picked up)
FOUR WHEEL POP-UP CAMPER, 2015 HAWK with SIDE DINETTE SEATING
Tons of Options and Accessories! Very, very clean!
A New 2025 FWC from factory with all of these options would be approximately $42,000
For sale by owner for $26,500. (2025 Hawk with Side Dinette price without options $27,750)
(*indicates owner-added or upgraded features)
All Aluminum “Flex Frame”
*Upgraded stainless steel turnbuckles with jam nuts
Mechanical Camper Jacks (4 corner)
Jack Brackets
*Aluminum Extension Plates
Corrugated White Aluminum Siding, One Piece Roof (white is cooler, corrugated/textured doesn’t show every scratch and dent)
Gas Strut Roof Lift Assists (exterior)
*Roof Lift Assist Air Jack by Aluminess, 450# capacity ($405 included)
*Small Portable 12V Air Compressor for Air Jack
*Built-in wooden “targets” for Air Jack to prevent ceiling damage
8’ Side Awning (used just a few times)
Side Dinette with Swivel table
Maple Interior Cabinets
Baltic Brown Formica Countertops
Flush-mount Stainless Steel Kitchen Sink with Electric Water Pump, Flush Cover
Flush-mount Two Burner Propane Stove, Flush Cover
Compressor 130 liter AC/DC Refrigerator with 10 liter Freezer (FWC 2024 model has 130L with very small freezer)
20 gallon Fresh Water Tank
Deer Valley Fabric
Privacy curtains
Linoleum flooring
*Interlocking padded floor insulation
*Removable washable carpeting (plus enough for a new piece)
Insulated Side Walls and Roof
Rugged Vinyl Side Liner
Has four windows, each with screen, clear, privacy, and thermal pack, all adjustable from inside camper)
Screen door
King Bed Slide-out for Cabover Bed (don’t need to crawl over other person)
*Under-mattress Padding/Insulation
*R-Tech 1.5” Thick Insulfoam cut to bed size (for use in very cold temperatures)
Thermal Pack (original)
160 Watt Solar Panel Mounted on Roof + Charge Controller
Dual Northstar NSB-AGM24M Marine Batteries, Wiring, Separator
30 Amp female to 15 Amp male Pigtail adapter with Furrion Powersmart to connect camper to shore power or generator
15 Amp 125V Duplex Outlet/Receptacle (use with shore power or generator)
12V Power Port and 4 USB outlets
LED Interior Lights
LED Outside Porch Light
LED Exterior Lighting Package
LED Rear Flood Lights
Roof Rack Yakima Tracks Installed on Roof
*Rear Wall Air Conditioner Frigidaire FFRE0533S10, 5000BTU, vinyl cover (not currently installed but has been, fits the space, includes flanges)
*Has clear polycarbonate window over A/C opening when A/C not installed
Rear wall steps (better access to roof)
Large Radius Louvered Passenger Side Window
Power Roof Vent Fan (Fantastic Vent Fan) over stove
Front Roof Vent over bed area (Wired for fan--not necessary, open both vents and run one fan)
Forced Air Furnace replaced Jun 2022 Dometic DFSAD12111
*Manual Thermostat (Honeywell CT50K special low temp scale from 35-85 degrees can keep water from freezing)
Hot water heater with outside shower package
*Window Insulation cut to size (both of the windows and the door window)
2 x 10 lb Propane Tanks with automatic switchover when one is empty
Porta Potti (used twice)
Ready To Go Anywhere Starter Package--Includes two Propane tanks installed with hoses and switchover valve, one 5 gallon graywater reservoir with drain hose and connectors, 1 non-toxic fresh water filler hose, extra fuses. Propane tanks are partially full. Will not include Product 303 wash/protectant.
Fire Extinguisher, LP/CO Detector, Smoke Detector, Safety Exit
*Yamaha EF2000iS Gas Generator (500.00+ included) (A/C requires shore power or generator)
*Rieco Titan 6’ Camper Dolly, assembled ($807.86 included) 6' Camper Dolly - Rieco-Titan Products To store your camper when not on the truck
Again, this camper is Very, Very Clean!
Please email: ssperling1 "at" verizon.net with serious interest
Jack Brackets
Deer Valley Fabric
Privacy curtains
Linoleum flooring
Screen door
LED Interior Lights
