2016 Four Wheel Camper Fleet - Front Dinette
fordnjh
Feb 23, 2021
1
For Sale: 2016 Fleet Four Wheel Camper, $22,500
Second owner, very good/excellent condition, well maintained, Carried by a 2015 Toyota Tacoma V6 4x4 double cab with 6’ bed.
$22,500
Features and options:
  • Front dinette w/ swivel table & fabric upgrade
  • Flush Mount stove and sink
  • 20 gallon freshwater tank
  • 6 gallon hot water heater w/ outside shower
  • Furnace with digital thermostat
  • Isotherm 2-Way 65L refrigerator
  • Thermal package
  • Hypervent mattress cushion
  • LED interior lights & exterior porch light
  • Fantastic fan (variable speed w/ rain sensor and remote)
  • Extra roof vent
  • 200W GoPower semi-rigid panels (new May 2021)
  • Victron MPPT 100/20 Smart Solar & BMV-712 battery monitor (new Dec 2020)
  • Dual 75ah AGM batteries
  • Bluesea Systems Automatic Charge Relay
  • Dual 10 lb. propane tanks
  • Yakima tracks
  • Mechanical camper jacks w/ upgraded aluminum jack plates
  • Rear-wall steps
  • Custom removable/lockable rear cargo box & RotoPax can
  • Back-up camera
  • Upgraded door bolt lock
  • Toyota Tacoma bed bars w/tie-downs and mats (for 6’ composite bed)
  • Portable folding steps, portable grey water tank, water hose, 30 amp pigtail
  • Complete paperwork and manuals
  • Delivered weight: 1305 lbs
Comments on condition: Camper has only been used on extended 3-5 month trips in western NA and is otherwise kept in storage. No dents, dings or scratches on aluminum exterior and regularly washed and waxed. Tent sidewalls are in very good condition inside and out and have been regularly cleaned and treated with 303 Aerospace Protectant inside and out. Mosquito netting and screens are in excellent condition with no rips or runs. Interior walls, ceiling, cabinets, counters and table are in excellent condition with no scratches, dents, dings or stains. Upholstery is in excellent condition with no visible wear. Solar system was completely upgraded in 2020-21, with new battery cabling, breakers, switches, smart Victron MPPT solar controller and battery monitor, and new GoPower flexible panels wired in series (panels replaced under warranty May 2021). All components are in good working condition (solar, electrical, fridge, stove, faucet, water pump, exterior shower, furnace, water heater, fan, plumbing). Batteries have been rarely drained below 70% and never below 12.2V. Camper is plugged into shore power while in storage. Minimal modifications (except for removable storage box), so interior and exterior are virtually the same as delivered from the factory. The very handy exterior storage box is easily removable with just 3 bolts/nuts and is attached to a frame that is bolted to the camper using existing attachment points, except for lower bracket which is bolted through the floor with a large backer plate inside a cabinet.
I fished for atlantic salmon out of one of these for two weeks. I'm not in a position to buy today but will be in the spring. Will keep an eye on this. Good luck.
