FYI - here is the Reliance Anti-Gravity Pump for the Reliance water jugs. I saw it used in a teardrop camper bit I can't tell you how well it works.Ourayphotography said:looks good! Do they make a hose adapter/pump for aquatainers?
Wow nicer job then mine [emoji3]shellback said:Ouray, Here's my Rube Goldberg set up for drawing water from the 7 gal jugs. I also chose the portable jugs as it's much easier to swap them out rather than trying to fill a built in tank. I used the same faucet the OP did. Here's my sink top also. Forget to mention, All the fitting were found at Home Depot. A plastic barbed fitting that screwed into the Reliance cap, then a piece of 1/2 copper that slid down through it. Then brass fittings to the quick coupler. I need to find some "food grade" fittings for the quick coupling though.
I am not aware of any direct connect fittings. I just place a reinforced water hose from the little 12v pump and into the opening of the aquatainer. I don't fill it quite all the way to the top and after a half dozen trips I haven't had any water splash out.Ourayphotography said:looks good! Do they make a hose adapter/pump for aquatainers?
jimjxsn said:FYI - here is the Reliance Anti-Gravity Pump for the Reliance water jugs. I saw it used in a teardrop camper bit I can't tell you how well it works.
Shellback, really like your camper and build.
very clean, looks good.shellback said:Ouray, Here's my Rube Goldberg set up for drawing water from the 7 gal jugs. I also chose the portable jugs as it's much easier to swap them out rather than trying to fill a built in tank. I used the same faucet the OP did. Here's my sink top also. Forget to mention, All the fitting were found at Home Depot. A plastic barbed fitting that screwed into the Reliance cap, then a piece of 1/2 copper that slid down through it. Then brass fittings to the quick coupler. I need to find some "food grade" fittings for the quick coupling though.
Thanks for the link
