2018 Ram Promaster Camper van
doinepicstuff
Jun 2, 2015
40
This is my third and favorite! Camper van conversion. The smaller wheel based van is an amazing platform that not only fits everywhere but gets AWESOME MPG and isn’t a pain to drive in traffic. The 136 wheel base actually fits in Bay Area parking spaces!!! It also blends in / is rather stealthy since it’s not as large as other vans. It’s even short enough to avoid the 23’ or greater parking bans some cities / municipalities are putting up. The front wheel drive will undoubtedly do better than other rear wheel drive vans (sprinter/transit) in the snow/off road. All this paired with the comfortable and techy cabin in a van that is actually fun to drive.
https://sfbay.craigslist.org/eby/rvs/6976634429.html
$60000 obo
Please don’t hesitate to reach out with any questions.
The van:
2018 Ram Promaster 2500 136 v6
approximately 8k miles – Still has factory bumper to bumper warranty and service plan (free oil changes to 50k miles)
upgraded multi position seats w/ passenger side swivel seat
Navigation
Bluetooth
Cruise control
Power windows (one touch)
Power / heated mirrors w/ integrated turn signals
Power fold in mirrors (helps to fit in tight spots)
Backup camera
Larger fuel tank
High output alternator
Tinted windows
Window flares / rain guards
All weather rubber floor mat
The camper conversion:
As mentioned before this is the third conversion I have completed and I can provide contact info for the owners of the two previous vans for recommendations/reviews if desired.
Walls and ceiling - are blue stained/beetle wood tongue and groove pine. This wood provides a unique look with a natural stain/design. This allows for a great look without the need to stain the wood (since off gassing is a concern in such a small space). The whole van is insulated with Thinsulate insulation to provide thermal insulation in both cold and hot climates. I also used 1 inch poly foam (in crucial places ie. Sleeping area / floor) to help bolster the ability to retain block out/heat.
Skylight / Fan – The skylight is a Arctic Tern with electric motor and LED’s. It includes a sliding screen and blackout/thermal shade. The top opens a full 90 degrees and provides great light / views as well as ventilation. Above the bed is a MaxxAir fan that provides forced ventilation and can remain open regardless of the weather.
Floor- 1 in poly foam board w/ 5/8” plywood topped with one continuous sheet of lined linoleum sheeting and sealed on the edges. This prevents any spills from going too far.
Bed – The platform bed is a standard full sized bed with a 6 inch memory foam mattress (VERY comfortable). The platform is built of birch to prevent sagging over time.
Cabinets / Counter – Cabinets are custom made to fit the van all drawers are soft close and have magnetic latches to keep them closed while driving. The sink is a highquality stainless steel bar sink with a strainer and drying rack. Faucet swivels flush against the wall to provide more space when not in use. The counter is solid butcher block treated with a natural mineral oil (again no off-gassing issues).
Refrigerator / Freezer – Dometic CFX 40 in custom built cabinet / seat (fits 60 cans) with wifi / phone connectivity. https://shop.dometic.com/store/dometic/en_US/pd/productID.5178067700
Gear storage / garage – Under the bed is a storage area approximately 40” H x 60” This area will house a ton of gear. It is currently home to 2 full sized mountain bikes, climbing gear, camping gear, etc. There is also a outdoor shower and this area is lit for those early morning / late night starts and returns.
Electrical – DC power is provided by solar and the vans high output alternator this function is mindless and hands off as it is controlled by a smart relay that automatically connects and disconnects. The 200 w of solar on the roof provide power to the smart MPPT Solar controller (with Bluetooth) all this power is then stored in 2 Renogy Gel batteries 200 amp hours. The entire process can be monitored on your smartphone or tablet so you can monitor usage etc.
A/C power is provided by a 2000w/4000w pure sine wave inverter. These are the more expensive but safe for expensive electronics inverters.
Lighting – provided by recessed LED lights in the ceiling / over counter. Paired with a touch panel dimmer switch. I also retained the factory lighting that automatically comes on / off when the doors open / close.
Water – 16 gallons of fresh water storage and 7 of gray. Both are easy to fill and empty. There is also an outdoor shower / rinse station plumbed into the storage area.
Campervan Sprinter Promaster Ram Transit Van Life
