VanGoOutdoors
Well, this is round two, sold the first one. Someone asked why I didn't post it here, and honestly, i had forgotten. So thusly....here it is
The current van
Of note:
Everything except the Winch mount, and flares were 100% fabricated by me. We produce the racks, interior frames etc etc etc.
Full aluminum construction with aluminum composite wall coverings and panels.
Only thing wood is the cabinet faces
new van! by Grant Wilson, on Flickr
So, changes from last one:
Queen bed instead of Full. Still the same layout, but wider
Front will only have a winch and hitch mount
Spare tire mounted to the door (rear bumper is just too killer to the departure angle)
Fridge will be under the kitchen area and slide into the door opening for ease of access in or out of the van, driver side cabinet will stay about the same, with smaller drawers instead of one big one.
Let it start!
I will keep a running tally of what i buy, literally as i buy it. I am not including any tools i buy, but i will factor in stuff left over from last build (some sound deadening and insulation for example), along with links to what i get on amazon, or another source.
Sound Deadening 2 boxes - https://amzn.to/2xkq3Mu - 127.98 (two boxes does a whole sprinter very well)
Installation tools - https://amzn.to/2LutUJH - 14.99
Insulation - 50 linear feet - https://www.ebay.com/itm/3M-Thinsul...hash=item1ead2f222b:m:mQsMt9R9kVO_5FNr6jaI3KQ - 600.00
Speaker adapters for door - https://www.ebay.com/itm/Speaker-Ad...m2109284bb3:m:mqnhvfnNVg7VtUD5gQ3IYaA&vxp=mtr - 26.00
Speaker panels for rear door - https://www.ebay.com/itm/Sprinter-N...hash=item1ebbe3678e:m:m2rs-20X9AmEqeaafqX9ycA - 100.00
Vented seat base panel for heater intake - https://www.ebay.com/itm/Slotted-Ac...230286&hash=item1e98f23050:g:hj4AAOSwa39UyG8D - 28.50
Espar D2 Heater with muffler, and easy start timer - http://www.heatso.com/eberspacher-airtronic-d2-12v-2-2kw-heater-kit/ - 992.00
Renogy 200ah batteries (x2) - https://amzn.to/2krTAuo - 595.98 (on sale)
Renogy 100 watt panels (x3) - https://amzn.to/2s9bPZK - 318.87 (on sale)
Midland Radio - https://amzn.to/2s8XlsC - 149.99
horn - https://amzn.to/2IOERnD - 24.94
Air Tank - https://amzn.to/2IOF2iN - 57.95
Air Bulkhead fitting - https://amzn.to/2s47GWX - 10.14
Rear shower - https://amzn.to/2sg90oZ - 50.00
Solar Y connectors (2 pairs) - https://amzn.to/2IQ0HLO - 17.00
ram mount - https://amzn.to/2GPKW1w - 32.99
Ram mount base - https://www.amazon.com/gp/product/B004O8LF26/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 - 9.95
Carpet for lining flares and trim (2ea) - https://amzn.to/2GQ0ceH - 65.32
Foam for lining flares (qty 5) - https://amzn.to/2Lv9jF9 - 65.00
USB plugs (x4)- https://amzn.to/2ILM3VP - 44.00
12V plugs (x4) https://amzn.to/2LsnVF8 - 28.00
Quick fuel connector for heater - https://amzn.to/2Lub6KI - 9.88
Ceiling LIghts (8) - https://amzn.to/2IKm40R - 65.98
12v dimmer - https://amzn.to/2xb2Xb2 - 30.00
Roof Solar Entry - https://amzn.to/2GRSgJT - 20.00
Main fuse panel - https://amzn.to/2LxCmIe - 35.96
driver wall fuse panel - https://amzn.to/2IOOpiD - 31.97
Solar wiring - https://amzn.to/2KVEQPy - 41.99
110 plug shore power - https://amzn.to/2s8z1am- 16.95
water Strainer - https://amzn.to/2xfL7nf- 8.11
water pump - https://amzn.to/2xckXBR - 71.13
Cable Ports (x4) https://amzn.to/2LsclKd - 90.88
rear switch panel - https://amzn.to/2JdeWcC - 57.72
front switch panel - https://amzn.to/2J7BFHe - 68.33
terminal studs (to add stuff to front battery, and manage rear battery connections) - 51.88
Flarespace Flares - http://www.flarespace.com/products/flare-set-for-mercedes-sprinter-van - 1750
Inverter/charger - https://amzn.to/2ILmEHA - 515.98
Ctek Smartpass 120 -https://www.quadratec.com/p/ctek/d250sa-dc-battery-charger-40-186?gclid=Cj0KCQjw6J7YBRC4ARIsAJMXXsdNzVWFwcdkzmpn5FAJghAVdukl19pTWqXl52tV9mom5GL0eI6UoNYaArdxEALw_wcB - 304.99
Victron BVM 712 - https://amzn.to/2IMsj4j - 206.55
Victrom 100/30 mppt - https://amzn.to/2J3DmFH - 226.10
Battery switch - https://amzn.to/2INVJio - 24.19
Total as of may 25 -6,948.26
Rockford Fosgate Power 400.4 - https://www.amazon.com/Rockford-Fos...sr=8-1&keywords=Rockford+Fosgate+Power+T400-4 - 300.00
Rockford Fosgate T1650-S components (2 pairs) https://amzn.to/2JgygGh - 430
Amp Install kit - https://amzn.to/2ITtSNW - 25.34
Line Converter - https://amzn.to/2LE5cqz - 8.16
Black and read heat shrink for terminal stuff - https://amzn.to/2GXQ4k2 - 8.99
4ga terminals (battery connections, inverter, etc) - https://amzn.to/2JezMIP - 9.99
0/1 terminals (for main wire to Ctek,) - https://amzn.to/2LBB5jq - 11.54 (it was almost same price to buy 4 a it is 10, so i got 10)
PA System - https://amzn.to/2sqZgZd - 149.99
Total as of May 28 - 7802.27
And more parts
BFG KO2 - 285/75-16 x 5 - https://amzn.to/2H6BHtY - 1000
ARB Single Compresor - https://amzn.to/2xu7Yvc - 266
ARB Air up kit - 34.62
Weather Tech floor mats - https://amzn.to/2xveVME - 195
Warn Zeon 10S platinum - https://amzn.to/2Jmu7Av - 1595.85
3091
Total as of 5/31 - 11151.12
1/4 air line - 19.00
3M super 90 (6 cans) - 54.00
Air fittings - 24.00
Rubber Grommets for wire pass thru - https://amzn.to/2sKOL2W - 16.10
AirUpDown Kit - https://updownair.com/ - 260.00
Tern Overland Window (biggest one)- 410
Headliner shelf - https://vanwifecomponents.com/product/shelf-headliner-for-sprinter/ - 400
Electrical plug (x2) - https://www.ternoverland.com/other-components - 102
Water fill (same link)- 49.00
Total as of 6/6/18- 12485.22
Ram mount stuff - https://amzn.to/2MabAWq and https://www.amazon.com/gp/product/B004O8LF26/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 - 46.93
Van Compass suspension - 2492.49
TOtal as of 6/7/18 - 15024.64
Wire totals - 450
Flooring - 180.00
Aluminum for fabrication- 680
Total as of 6/10/18 - 16334.64
Ceiling material - 80.00
pvc trim board for window spacers - 14.00
Rubber gasket for metal to metal areas - 8.00
latch for bed - https://amzn.to/2LVRNt9- 6.49
Outlets for driver side wall-https://amzn.to/2JNaVg6 - 22.99
200a CB for inverter - https://amzn.to/2JJWiua - 27.99
150A CB for smart pass- https://amzn.to/2JKD5IJ- 23.99
total as of 6/17/18- 16517.46
bedslide ordered
BEDSLIDE S 62" X 43"
(1-6243-S) - 899
total to date:
17,416.46
https://www.etsy.com/listing/288760045/1-yard-36-x-55-lilly-pulitzer-summer
Ordered the fabric for ripplewear to make my shades
Total as of 6/19
17570.90
Misc Home Depot run - 174.34
Rack lights - https://amzn.to/2yxxnVr - (x3) 110.99
Side and rear rack lights - https://amzn.to/2JY7ByZ - (x3) - 30.00
Total as of 6/22 - 18168.18
Dometic Stove (mo8322)-https://amzn.to/2zkuSX8 - 499
Dometic Faucet - https://amzn.to/2MRYLQo - 100
Dometic CFX75DZ - https://amzn.to/2KRhGKs - 1k
Fridge SLide - https://amzn.to/2MRygKZ - 300
Penguin 2 AC unit - https://amzn.to/2u8wc9l - 800
Thermostat and air distribution panel - 250
MAxxair Fan - https://amzn.to/2tWJMxh - 250
spray adhesive (6 cans of super 90) - 66.00
total as of 7/5/16 - 20633
(stopped counting past this point. Depressing. )
The current van
Of note:
Let it start!
And more parts
3091
Wire totals - 450
Flooring - 180.00
bedslide ordered
(1-6243-S) - 899
total to date:
17,416.46
Total as of 6/19
17570.90
