leadsled9
Contributors
Finally got around to installing the air compressor. I did the research and was impressed by the ExtremeAir Magnum Compressor. This is the compressor I purchased: http://www.extremeoutback.com/product/14/ExtremeAire+Magnum.html
Here is a link from Expedition Portal with some great videos: http://www.expeditionportal.com/resources/air-compressor-series.html
So, I bought the compressor, air tank and mounting kit. Note the custom mounting plates I had fabricated to use existing holes in the frame to mount the compressor and tank. I don't like drilling holes in the frame as every hole weakens it and is an entry place for corrosion to start.
Here's the mounted circuit breaker:
Here's the fused switch and circuit breaker:
