melcooke
RV/Camper Electrical Systems Rookie here. I don't know where to start troubleshooting so I'll list the circumstances.
When we returned from a 7 week time away from home (truck was parked the entire time) and I went to start the truck the battery was totally dead.... nothing lit up in the truck, zilch.
I connected my portable charger and set it to 12 volts/2 amps. The gauge pegged to 8+ amps (max amperage on the charger). When I switched to 12 volts/8 amps, same result. I thought this odd but have not experienced a scenario like this before.
Out of curiosity I turned the truck key on.... zilch. I let the batter charge for about an hour.... zilch. The charger cycled about every minute of so between 0 amps and 8+ amps, I suspect a cooling circuit was engaging to prevent overheating.
I disconnected the positive battery cable and the charger went to 6 amps (where it was set) The battery was now taking a charge and there are lights on the dashboard, and a dead battery click when attempting to start.
I then reconnected the positive battery terminal and disconnected the positive line that runs from the truck battery positive terminal to the camper house battery in our All Terrain Osprey. Truck battery still charging.
At this point there was no power whatsoever in the camper.
I connected shore power to the camper and my Victron Connect monitor showed 13.27 volts, 100% charged, infinite time remain but 8.92 amps of current! Hmmmmmm. I'm assuming the current is shore power charging the house batteries (2 12 volts AGMs). This does not make sense to me but I'm a novice at RV power systems.
All of the 12 volts accessories work fine with shore power connected.
Out of curiosity again, after about 1/2 hour of being connected to shore power I disconnected shore power. The camper positive power lead from the truck batter is still disconnected.
The Victron Connect shows the house batteries to be at 11.5 volts, 100% charged, infinite time yet still showing 6.9 amps! This just doesn't make sense to me. Current to what? A short to ground somewhere?
Also, seems the battery cutoff in the camper should have stopped the truck battery from draining if the camper is the problem and should have prevented the camper batteries from draining if it is a truck problem.
