Bradders
So I have just fitted an Eezi-Awn Bat 270 to my Wildcat Four Wheel Camper (equivalent is a fleet I believe). Because of the length of the awning, I would have to move the roof hold down clasp on that side of the camper (the left in my case as I’m in the UK). This would entail sealing up the old holes and drilling new ones in the side to accomodate the new location.
However, an alternative to this could be to reduce the length of the clasp lever. The very top part could be cut off and then a piece removed which was enough to clear the back of the awning. The top could then be welded (tig, mig or stick) back on.
Obviously, the hook part of the clasp would have to remain the same length and so when open, would rest against the back of the awning, but I can’t see that being an issue.
So it would not look as pretty when closed, but it would be hidden by the awning when the roof is down anyway. Also, there would not be so much leverage for opening and closing the clasp, however if one tries to open and close a full size clasp by holding it at the half way point, it seems to be quite achievable.
So I was wondering what the consensus of opinion is… good idea and get it done, or bad idea and don't be such an idiot.
Here is a photo which sort of shows what I’m trying to say (apologies for the quality).
