Conestoga
In our Hawk, the porta potty lives in a space to the right of the door. Being rectangular, the storage was always 90 degrees to the use direction to allow the head to clear the door threshold extrusion when sitting solidly on the floor. Moving it in & out was a lifting & twisting exercise with a heavy unwieldly object.
We have seen some really nice solutions where people included it in a cabinet with a drawer slide, however, we wanted to keep it simple. We solved the problem by building a roller platform which allowed the head to be turned to the use position & provided clearance over the threshold extrusion when stored. The rollers are PVC pipe with plastic bearings in the ends mounted to aluminum angle with full length axles. The platform is black marine lumber (Starboard) for cleanliness and strength. The lock is engaged or disengaged with a quick release pin to keep the roller platform in place when traveling. Could be made simply from plywood or whatever you may have at your disposal with hand tools.
