esimmers
- Joined
- May 15, 2010
- Posts
- 170
I purchased from PowerStream <http://www.powerstream.com/> a PST-BC1212-15 DC charger for charging my 12 volt camper battery from a 10-15 volt source (my truck alternator and starting battery). It has a 4 stage, 3 level microprocessor controlled lead acid battery charger built in and outputs about 7.5 amps. If I drive long enough, it does an excellent job of topping off my camper battery.
I have one problem with the unit about which I'm corresponding with the manufacturer who, I must say, is quick about responding to emails. The charger is normally activated by an ignition-on wire which is supposed to close a relay allowing the charger to accept current from the + input wire. Alternatively, there is a rocker switch which activates the charger when there's no ignition signal. I only want to use this rocker switch sparingly since it draws current from the truck battery with the engine off.
When I activate this rocker switch, 12 volts is output to that ignition-on terminal of the charger. That's a problem because my truck aftermarket stereo is activated by the ignition-on circuit. Whenever I activate the rocker switch, my truck stereo turns on.
I've written PowerStream and was told there shouldn't be any current applied to the ignition wire when the rocker switch is turned. I've asked for a replacement unit that doesn't have this fault.
If you have one of these units, would you test it to see if activating the rocker switch sends a 12v signal to the ignition-on wire? I'd sure appreciate it.
Thanks
Ed
Thanks
Ed
