Atwood Plug & Lithium upgrade
MTCruiser
Dec 3, 2021
Posts
22
First time poster and I’ve read so many of the Lithium threads but still don’t understand what to do about the running lights on the camper. I have a 2021 Hawk and it only has the Atwood trolling motor plug (currently) that is in the drivers side corner of the truck. I know that when I go to DC to DC I will be using Anderson connections, but I dont understand the delete of the current plug?
Do I also remove the relay that is in the camper?
Do I just cut the positive and negative from the Atwood plug and leave the other wire to send signal to the running lights?
I have all the materials to complete install just trying to figure out this piece. I searched and didn’t find a clear answer on here.
Does anyone have photos of what they have done?
I don’t know enough about the relay to provide meaningful information, but from a simplistic view, I would just disconnect the positive from the Atwood connector where it is attached to the bus. Leaving the 12VDC clearance lights power, and the ground intact.
Got ya, so I would still plug it in when connected to the truck? I can take pics in the morning to show a what I have.
+1 to what WS said. The DCDC replaces any isolators in the rig. If you replacing the wiring with heavier gauge wire, you bring that wire all the way from the starting battery to the bed of the truck where your anderson plug will be. If you can open up the camper enough, you replace the wires in the camper too, up until a breaker. From the breaker you can run a shorter length of 6 AWG (biggest size the Victron accepts) to the DCDC.
I'm not sure how your running lights are powered. Perhaps someone else can chime in....
Which Hawk interior layout do you have? If it’s the front dinette, they run the campers wires along the exterior of the camper back to a hole that goes up into the cabinet immediately forward of the battery compartment, making it very easy to replace the whole run back to your dc to dc charger you will install. If it is a front dinette, my 2021 Grandby is almost identical and I could walk you through what I did when I installed my lithium battery, chargers, and monitor into my new camper.
As mentioned above, the running lights were tapped into from your rear brakelight, if the install was done by 4WheelCampers. I decided to run 6 ga. wire throughout and just replaced the Atwood plug with this item.
https://www.amazon.com/dp/B06Y5XQQNV
Used the new 6 ga wires to replace the the factory 10 ga on both sides, and the original running light wire on both sides.
I have a side dinette wire comes in one of the storage areas front drivers side corner
I have a Blueseas ACR. I went lithium and don’t use truck to charge, only solar. I simply disconnected the ground on the ACR. I have running lights but battery systems are now totally separated.
Is this the ACR?
Pics:
Automatic Charge Relay (ACR) is similar to a Voltage Sensitive Relay (VSR). Each model will have different features, even within the Blue Sea line of ACR's they have different capabilities.
So I disconnected the positive going into my voltage relay. Should I just wire nut this? Is there anything else I need to do?
The running lights still work so think this is what you guys were saying to do.
Is there any danger with having the camper have 2 grounds? The Atwood plug and the dc to dc charger ?
Two reasons not to have parallel grounds:
1) Safe return of operating and fault current. People don’t normally fuse ground wires. It’s all fun and games until your larger ground connection fails for some reason and the smaller wire has to carry all the current. You don’t know it’s failed until you apply a large load and smell overheated or melting wire (if operating current is excessive), or until the remaining wire competely fails later due to a second failure (if a large fault current occurs). Redundant grounds are acceptable and desired for some situations IF both grounds can safely handle the entire operating and fault current (and if it doesn’t create issue #2.)
2) Ground loops. If you have different loads connected to ground at different locations and have parallel grounds wires you can end up with slightly different voltages on the ground wires at different location, with one load potentially affecting the operation if another load. Also, if the ground wires take different paths such that there is an area between them, current will be induced in the loop by electromagnetic fields. This can affect operation of sensitive equipment like radios.
Others may have more specific examples where multiple grounds caused a problem.
Okay…. Thanks. So I’m confused how do I fix this and leave the running lights working ?
Both the dc to dc charger and the Atwood plug are grounded to the battery.
I swear everything about this install seems to make sense to me besides this damn plug.
The running lights are grounded to the camper’s negative bus bars, which are connected to the camper’s negative battery wire before you began making changes. You are going to connect that main negative camper wire to the camper battery negative (or a connected bus bar), which will be connected to the negative wire from the truck (assuming you are building a non-isolated system). When you connect the running light positive wire to a light circuit on your truck, the lights will work because the current can return to the truck battery via the main truck-to-camper negative wire.
So I can leave it like pictured?
