bad solar panel?
joez3
Feb 8, 2011
Posts
54
Last night I was checking out some stuff in my camper and found that the fuse on the battery was out. I have a 50 watt solar panel, when I disconnected this, everything was ok again. I checked the solar panel and it was putting out 15v with no load. I ran out of time to check on the solar panel wiring. Could this be a sign that the solar panel is going bad?
Most RV type solar panels are rated around 17 to 18 volts. Your charge controller steps the voltage down so you aren't feeding this higher voltage into the batteries. Depending on how much sunlight you had when you checked the panel output you are in the ballpark.
Most likely the problem in in the wiring, check behind the lift panel where the wires go up to the roof, this is a common problem as the wiring used in this location isn't designed to flex, mine is just regular THHN stranded, not a multi strand flexible cable.
Dsrtrat
Agree, there's a problem in the wiring somewhere. Start with dsrtrat's suggestion. An ohm meter helps check continuity.
