riz
I've had three different 80's Fleet campers and every one of them had rotten lift panels. After spending long hours, frustration, and a lot of swearing, I've decided that replacing the panels myself is a royal pain, and having it done is way too expensive. Here's my solution: Two 1/2" galvanized floor flanges (about $12). Two 1"x1/2" reducing pvc elbows (a couple bucks). Two 1"pvc caps (less than $2). A stick of 1" pvc pipe ($5?), and a piece of 1/4" plywood 6"x6' (found it laying in the scrap pile). Take out all the old panels and hinges. Screw the plywood to the top of the camper across the front. Screw the floor flanges to the front corners of the camper frame. You can back them up with some wood to have something to screw the bottom screws into. Thread the elbows into the flanges. If you can't find an elbow with male threads, you'll need a short galvanized nipple to link the elboew to the flange. Put a stick of pipe about 24" (your length may vary) long into the elbow (no glue needed). Put a cap on the other end of the pipe. Use the threaded elbow as a hinge to lift the pipe vertical so the cap rests on the plywood on the ceiling. With a pipe vertical in each corner, the roof is supported. You can drill a small (about 1/2" diameter) hole in the plywood at the appropriate location to keep the cap from sliding around. The process takes about an hour, and costs about $20, opposed to a weekend (or more) of swearing and misery trying to fabricate new panels using rotten garbage as your pattern. Here are a few pictures of the latest project:
This shows the lift arm in the down position (front left corner)
This shows the plywood attached to the ceiling with a hole for the top of the lift arm to slide into.
This shows the lift arm in the up position.
closeup of the top.
closeup of the bottom.
closeup of the top.
