ski3pin
Silent Mode
Site Team
RV LIFE Pro
Julie and I have been in lots of wind lately and would like to reduce the noise from the unlatched latches rattling. These are the latches that secure the top in the down position. Any cures?
I went out and tested this idea. It works really well. Thanks Bill!I'm going to assume you mean when the top is up as that was the rattling that drove me crazy when the wind blew at night.
I found I could lift the latch handle up and when it got nearly vertical, I could feel the resistance of the detents near the hinge grabbing & holding the handle at about 11 o'clock (if you get what I'm saying.) The handle would stay up and the threaded latch would lean against the handle and not rattle in the wind.
Now my routine is to lift the latch handles up every time I raise the top. No rubber bands or tape needed. Plus if I forget I can still lower the top without a clearance issue.
I just tried flipping it vertical and the over center mechanism kinda "sticks" as you say. I kept going over the top. But the wind died down. Last night would have been the perfect test, darn the luck!
I'll have to stare at it to see why it sticks. My guess is there's a little stressing between the two joints. If the hinges wear it may not stick as well. Maybe when I get home...
Except when there are thick infestations of noseeums ...Never, ever complain that the wind died down.![]()
Awesome, thanks for that heads up
