Re: Chet
No, but my experience with them has been that they are easy to break when separating them. I have never broken PowerPole connectors. The SAE flat connectors wear out or are deformed & must be replaced.
MC4 are connectors of choice for permanent connections where water proof connections are important. They are easy to install as are PowerPoles.
Powerpoles are easy to set up as polarized multiple conductor connections meaning you can’t plug them incorrectly. An advantage is that it is easy to choose the wire size required for the current being carried.
The SAE sockets are a pain to install and you need to have versions on hand where the wire size is appropriate for current carried because the connector is molded onto the wire.
I use all of them and make short adapter cables to go between circuits with different connectors as needed. My uses are biased by my need to be able to connect changing devices for a short time for my ham radio hobby, but I have used each of these in my Hawk.
