Door issues, need advice
Sagefemme
May 20, 2024
Posts
155
Western Oregon
Last weekend we arrived at Summer Lake, Oregon at about 9 pm. There were lots of mosquitoes. We got set up quickly and retreated inside to escape the bugs. As always, a few mosquitoes came into the camper with us but were easy to kill. And kill, and kill, and kill some more. At some point it became clear that new ones were getting in somehow. We had the screen door closed and the main door open.
In the dark I couldn't see where they were coming in. When we closed the main door they stopped entering. Next morning in the light I realized the screen door was not sitting tight against the doorway, in fact the gap at the upper corner opposite the hinge was huge! But there was some gap all the way across the top almost to the hinge, and all the way down the free side to the floor. The door does not look obviously bent.
Today I partially fixed the problem by moving the latch closer to the door frame. Now the majority of the gap is gone except at the upper corner. There is a thin piece of fuzzy weatherstripping around the door frame. I am tempted to get some beefier weather stripping or felt and just glue it to the frame to fill this gap. Has anyone had this issue? How did you fix it? Is this a sensible approach?
While I was looking at all this I decided to address another problem which is when you're inside the camper you can't get the red lever that controls the deadbolt to turn as far as it would need to to be functional. In other words, you flip the lever but you can still open the door. The tongue is not in the opening in the door. I realized that the latch is very misplaced--needs to move down at least 1/4 inch for the deadbolt not to strike it. I will have to enlarge the opening at the bottom. How best to cut the aluminum so I can move the latch down? You can see it's already been moved down once. PS the gap at the top of the door is much smaller now that I have moved the latch, but it's still big enough to let mosquitoes in.
On our campers, the screen door would often get bent down from even light pressure when getting out of the camper and opening the screen door. Simply pushed up on the bottom of the door fixes it. Have been looking at replacing the screen door with a hanging curtain bug net using velcro or something. but have not gotten to far into it. In really bad bug condtions, have heard of mosquitoes coming in through heater vents and any small opening you normally would not think about.
We have needed to refresh the crack fillers with new foam weather stripping each year or so. It’s stacked two layers deep in that corner above the latch.
I will try pushing up from the bottom to see if that helps.
Yeah, I think what I would do would be to try some gentle gradual bending and then reline that fuzzy strip around the edge. We have been known to spray a bit of repellant around the edges of the door before shutting it for the evening.
How was the birding?
Yes, I will be gentle with my door probings!
Birding was lovely. We were helping with a nesting shorebird survey that Oregon Dept of Fish and Wildlife does every year for some time now. It's organized by the guy (Marty St. Louis) who managed Summer Lake Wildlife Area for 40 years before he retired.
The species of interest, that we were most concerned with counting, were snowy plover, killdeer, black-necked stilts, American avocet, western willet, Wilson's snipe, Wilson's phalarope, and long-billed curlew. These birds all breed at Summer Lake but, as these alkaline lakes shrink with draught and over-irrigation, are at great risk.
We also saw lots of white-faced ibis, tundra swans, Caspian terns, Forster's terns, western and Clark's grebes, eared grebes, and many more!
Wow! What a great accumulation of sightings.
