As so often is the case a small project turns into a massive one. It started like this:
Our bed board was completly rotted and growing lots of wild little things
Very squishy
Rotten mush
I called FWC's and Chicali gave me some good tips on getting the new board into place (the rotten one basically fell out).
As you can see the rail was pretty nasty with mold and corrosion. Some areas of the aluminium are pitted as well. I went at it with a wire wheel and it cleaned up nicely. I should also mention that I did all of this wearing a particulate mask. The oder from the mold was litteraly overwhelming.
I decided to use a sanded 3/4" plywood with a healthy coating of exterior paint for the bedboard. I read all the threads here on the forum regarding this project and this was the simplest and best option for me.
Cont...
Very squishy
Rotten mush
Cont...
