?? For my northern friends running lithium battery
dennis 221
Oct 11, 2019
Posts
459
Do u flip off the circuit breaker in your engine compartment during winter months. Seeing how they won't be charging in the cold..11 degrees now
0*F here these days. I keep the breaker(s) on, since I've setup the electronics are setup to NOT charge when the temp is below 40*F or so. That said, I have heater running in the camper to keep it above freezing so that when the sun is shining it can charge both the camper and the truck.
Most lithium batteries have a BMS that will preclude charging below ~35F/2C. On some of these you can tweak the temperatures to be higher or lower if you prefer.
Just wondering if by throwing off switch would release Alternator over working
By “alternator over working” do you mean charging too much? With no house battery attached, I don’t think that’s what you mean. Or are you thinking of some kind of Alternator run-away with a sudden load reduction? Your truck battery is still attached, so, it isn’t as if there would be NO load. Or am I not getting your question at all?
So ,i guess your saying there will be no juice going into camper at all. Thus Alternator will not work more with breaker not tripped.
I think your alternator will be fine. I am presently running my 2015 Silverado with a direct connection to the camper. I have seen 50A going into the camper, but that's a reasonable load for a 220A alternator.
