I've skimmed this thread and some of it brings a smile. This thread caught my eye because the 2GC AGM's are starting to go away and I've been looking at LiFeO as the likely option. For just us I think 100AHr is likely enough, but throw in the granddaughter and 200 may not be enough. Heated vs. not has been a concern.
Way back when I put in 6 ga. cables there was some push-back that I didn't need anything bigger than the 10ga. that the camper mfg supposedly supplied (older used Phoenix, so there was none). By my calcs at the time using the Ancor Resources page for reference, 6 ga. was as big as I needed to go for a less than 3% Voltage Drop at 30 amps over the roughly 25 foot total circuit length. A not much longer circuit length would push it to needing 4 ga. Doesn't take much voltage drop to really put the crimp on direct charging the camper batteries. DC-DC in those days really wasn't an economical option. With a non smart alternator truck I'd rather not go the DC-DC because when sitting in the yard I like that the solar will eventually close the ACR/VSR and pull up the starting batteries too. A DC-DC won't do that, and since the ACR/VSR's sold these days are, AFAIK, all dual direction sensing (unlike the single sensing VSR that I first used in the first camper and then gave away when I replaced it with a dual sensing) I can't put one in parallel with a DC-DC converter to charge the starting batteries with the camper solar. Going LIFeO might just force some compromises in other areas.
I put the ACR or VSR in/near the camper batteries as well. It doesn't matter where it is physically so long as it is in the circuit.
On the first camper I used weatherproof cord-grips to pass the cables thru the lower camper wall. On the second camper I used them again, but this time in an exterior electrical box because that made the most sense. I've been debating the need to do it at all with this camper
In our first camper a 100W panel more than kept up with the demand, which was mostly the compressor fridge. I used 8ga. to the camper roof with an exterior electrical box on the roof for the solar connection. The second camper came with a 160W panel installed, and it barely could keep up with the fridge. It was wired with all 10 ga. This third camper is getting two 200W panels.
