howtomountaingoat
- Joined
- Mar 1, 2023
- Messages
- 8
null
Planning on it, what amperage would you recommend?Vic Harder said:When running your 6AWG (or bigger) wires, remember to add breakers at both ends so that a short won't cause a catastrophic disaster. I used Blue Sea 285 series surface mounts on mine.
What Jon R said above is a good guide.howtomountaingoat said:Planning on it, what amperage would you recommend?
The Orion produces heat, but I have not found it to be a problem in my closed Grandby battery compartment. I’ve stopped and checked it at rest stops. The only vents in my compartment are the two 2 inch round exterior vents. Mount it low and per the instructions.howtomountaingoat said:Thanks everyone. I am all kitted out with 4awg wire, 175amp anderson plugs, two 50amp blue sea breakers, and two 150ah batteries for 300ah LiFePO4 storage total. I also added a 1000watt inverter with a 150amp blue sea breaker. I am planning on adding a vent similar to the vent that covers the IOTA to the interior battery box wall the give even more ventilation (it has small circular vents to the tiedown area, but id like the interior wall to also have venitalation). I've also installed a temperature monitor so I can monitor battery box temp from the truck drivers seat for longer drives where the Victron may get hot. If temperature is a constant issue I will add a barrel latch to keep the battery box hatch open during drives.
So far, so good. The existing Zamp PWM controller + 160 watt panel tops off the batteries to around 98%. The Victron 30amp DCtoDC charges the batteries FAST. Both batteries were at 80% and after a run to the grocery store both batteries were topped off. Inverter charges phone, laptop, and runs Starlink router without kicking the internal fan on.
Thanks again.
Non-isolated will work fine, and is what most people use.maurzog said:Thanks Jon super helpful. I started the teardown today and seems straightforward, 200 AH battery barely drops in, few hiccups like the anderson plug I ordered but at least should have all the wiring done tomorrow.
One question I had was I got the non-isolated Orion and was just going to run the single ground back to the bus bar, no reason for the isolated version I assume, correct?
I am in the midst of upgrading a 2009 HAWK to a LiPO4 battery and installing the Orion non-isolated 12-12/30 DC charger. I assume that this charger will replace the Sure power 1314A battery separator. I do not understand if I should connect the Iota DLS30 charger/converter to the "IN" connection of the Orion DC charger, or if this line should be extended to connect directly to the new LiPO4 battery (+ BUS).Jon R said:In a stock Hawk with an electrical system, the positive wire from the truck goes to the Blue Sea ACR, then to the fuse panel hot bus. It does not go “through” the DLS30. The DLS30 output positive is also connected to the fuse panel hot bus. Finally, the battery positive is connected to the fuse panel hot bus via the silver push/pull switch.
If you install a dc to dc converter, you will change the truck positive wire to go straight to the dc to dc converter (and nowhere else) and the dc to dc converter output goes directly to the battery or your battery bus bar. You would disconnect the truck power wire from the ACR and disable the ACR by disconnecting it or pulling the inline fuse. Appropriate fusing was discussed above.
You can leave the DLS30 as is to use as a shore power 120vac to 12vdc converter.
