NorCalSteve
I did not see any posts about this so I figured I would post it. To lock the deadbolt on my Hawk camper, I really had to lean into the door to get the key to turn all the way in the lock position. I had tried to determine exactly what the problem was a number of times and finally think I figured out what was going on and have fixed it. The cover plate for the dead bolt was sticking out so far that it was cutting into the seal around the door and pressing into the metal of the door. So I really had to put my shoulder into it to get the lock to lock. Notice that the top (deadbolt) plate sticks out further to the right. The plate can not be removed so I had to grind it back while it was attached to the camper. Well, I used a belt sander and took it slow so things stayed cool.
and
I ground down the front, right side in pictures, of the top cover plate, so it did not stick out as far. Below is the after photo where the top (deadbolt) plate has been ground back. This fixed my problem and the door now locks and unlocks as it should.
Steve
Steve
