mannydiles
Hi all,
I have a 2022 hawk that I had converted to lithium. It has a 25A National Luna dc dc charger in the system.
The shop I worked with installed what looks to be a 10awg wire running from the charger to the + terminal. Should I install a fuse at the battery for the wire coming from the charger? Should that wire be a 6awg as to meet national Luna recommendation too?
Also the kill switch, 10awg, wire headed to the fuse box is connected to the same aux terminal as the wire headed to the + post on the battery. Any issue with that?
I am probably over thinking this as it was a reputable shop and I have had no issues this far so the the setup.
