Smokecreek1
Smokecreek1
Hark! I just filled my 05 Granbys water tank up in preparation to leaving for Eagle Lake When----water started seeping onto the front floor in the camper. I pulled the battery, all the top boards and I can't get the front ply board out so I can see where the hose(s) attaches to the tank and/or check for leaks! Probably some left-over water in the tank froze last month-don't know! The water appears to be maybe an 1/2 deep in the compartment, but again I can not look if that is true, and I can't see if there are any obvious leaks. The tank gage reads 1/3 tank and the water drip under the left side has stopped. So, I decided to stop, before I got mad and started sawing and ripping things apart! So (1) how do I get the board off (if I need to) and how do I get at the tank! (2) What happens next like what I need to check next or not to do next. and (3) is there some type of tank sealant I can put in and stop the leak! I feeling that the tank sprung a leak, and problems not at the hose connection! I hope I can fix this here in Susanville and not have to go to the one and only RV shop here or to FWC to get things fixed! Any suggestions, help would be greatly appreciated ! Looks like it's almost dry in the cpt now!
Smoke
