Continued from above...
Test Fitting...Holds super secure...Nice!
Installing the TRIO Lexan top shield. I like the idea of the Lexan shield to protect the Starlink from tree branches, hail storms, etc. The shield is made to bolt flat against the TRIO mount and comes with the hardware to bolt the unit in place. Since I live and often travel in the hot desert I decided I wanted to add some spacers and elevate the shield away from the mount to create and air gap and allow the Starlink to breath and run cooler.
Spacers Installed....That's suppose to say Cooling lol.
Fabricating an aluminum mount for an SAE connector that I will use to connect/disconnect the Starlink to power.
Continued below....
Continued below....
