I have put that camper on your size truck before. Only problem with the small engine is that when you go up hills it is going to slow down on you.
I would not suggest leaving the bed liner in the truck. We won't install a camper at all over a bed liner. My question would be, why do you want to leave the bed liner in?
I also would not use the tie downs that you mention to hold the camper. They were not designed to hold a camper down to the truck. You should be able to see the way the camper is installed when you take it off the other truck. The eye bolt placement should be the same on your truck.
If you have any questions, you are welcome to call us at 800-446-1003 or give FWC a call at 800-242-1442
Thanks for the quick reply. I will remove the bed liner once I figure out how this is down. I haven't really looked at it. I wanted to keep it on the bed because I don't plan toalways leave the camper on the truck. The camper is in a different state. I would have to drive, look it over, decide whether or not to purchase. If I purchase THEN drill my truck, put in the eyebolts and transfer the camper and come home. This is a spooky proposition.
I just went to the FWC site(yours??) and read the FAQ. Very nicely done by the way. I guess the exact placement of the eyebolts onto the truck bed can be estimated. As long as they are just behind the wheel well and front of the truck. I would love to have the eyebolts in place before I go up there if that is possible. Charlie
