IOTA DLS-30/IQ4 12v 30A Converter and Charger ($100)
kmcintyre
Nov 8, 2008
Posts
1,484
Boise, ID
This has been in my camper for a few years. Works great although I rarely used shore power. Any questions, let me know. I'll be at the FWC Rally in Idaho next month if anyone is interested.
For more info, see:
The DLS 30A Power Converter/Battery Charger from IOTA converts nominal 108-132 AC voltage to 13.4 DC voltage for both DC load operation and 12V battery charging.As a power supply, the unit's tightly controlled regulation allows the user to operate a nominal 12VDC load up to 30 amps.As a battery charger, the unit will maintain the battery, delivering its full-rated current when the battery capacity falls sufficiently low.
The voltage is set to deliver its maximum current for the necessary period of time to minimize undue stress to the battery caused by heating of its cells. This helps to ensure the longest possible life of the battery. Over time, as the battery nears its full capacity, the DLS will automatically drop the current, providing a float-charge to the battery to prevent self-discharge of the cells.Input Voltage108-132 VACInput Frequency50-60 HzOutput Voltage13.4 VDCOutput Amperage30 AmpsThe DLS 30A Power Converter/Battery Charger from IOTA converts nominal 108-132 AC voltage to 13.4 DC voltage for both DC load operation and 12V battery charging.As a power supply, the unit's tightly controlled regulation allows the user to operate a nominal 12VDC load up to 30 amps.As a battery charger, the unit will maintain the battery, delivering its full-rated current when the battery capacity falls sufficiently low.
