My wife and I just bought a 1980's Keystone. It is in generally good condition except there is a crack, about a foot long, in one of the wooden boards in front holding up the top. Just curious if the boards are the only stuctures holding up the popped top and what should be done. Thanks.
Steve
Steveh,
The folding panels at the front and rear of the camper are the only structures holding up the roof in the raised position. When I bought my '98 Grandby used, the board were delaminating and falling apart. All they are is two pieces of 1/8" or slightly thicker plywood with either a woodgrain or white laminate applied to the face. If your handy you could probably replace them yourself. The only trick is the spring loaded hinges which can be a real bear!
Good luck!
Rick
