I've got a 2022 Hawk. I'm getting water in through the velcro windows when rig is stored on the side of the house and top is down. Only on the front two windows. Usually after a bit of snow has melted, but also with rain. I've also had leaks when driving though rain. It seems as if the water is getting under the roof and tracking to the velcro windows (which are obviously not waterproof) then slowing leaking in which leaves my bed damp.
There is quite the gap between the outer portion of the roof and the base it's suppose to be covering. In fact I can see the vinyl. it makes sense that water could make its way in there.
I've seen some similar posts and some thoughts on how to remedy. I'm curious how common is this issue?
Yesterday I put some automotive weather stripping around the front corners and over the front windows. Seems to fill in the gap but it was harder to close the top. I had to loosen the roof latches quite a bit to get them to close. We'll see if it helps.
