Thanks again SunMan for getting me headed in the right direction! I must have been using to much info in the search function. Got the panels out - fabbed and getting ready to clear coat the wood. Used a rachet bar (2 piece pipe with a rachet in the middle and rubber pads on the ends to hold roof up for disassembly. The kind used for securing a load in the bed of your truck.) Opinions needed reguarding fastners to secure hinge to roof. The bottom hinge is attached with screws does anyone see potential problem with using screws in the top hinge where it attaches to the roof portion? The original had rivits but figured good enough for bottom should work for top or is there a differance in tubing thickness? Thanks - appreciate all the info this site provides and look forward to contributing. Thanks
