slosquirrel
- Joined
- Apr 25, 2013
- Posts
- 32
Greeting all. Apologize if this has been discussed at length in other posts, but hoping someone can chime in on my specific setup (paging Vic "Doctor Electric" Harder).
Recently upgraded my 2020 Grandby Front Dinette from two (2) Deka Intimidator Deep Cycle AGM's to one (1) Epoch Essential Series 300ah LifePo4.
Did a ton of research and it seemed like a good mix of quality, cost, power, etc. It fit in my battery compartment like a glove and tripled my usable ah's from ~80ah (assuming 50% discharge with AGM) to 300ah!
While I was at it I installed a Victron BMV-712 Smart Shunt / Battery Monitor (which replaced the overland solar monitor in my cabinet), and connected a Victron VE.Direct Smart Dongle to the overland solar 100\15 MPPT controller (just a rebranded Victron).
I knew ahead of time the IOTA DLS-30 IQ4 charger / converter that came factory installed in my camper isn't "ideal" for my new Epoch battery, but based off what I've read on here and other forums I figured it wouldn't hurt. After I purchased my battery I reached out to Epoch with the communication below:
"Good Morning,
I have an Iota DLS-30 IQ4 charger/converter in my camper that isn't programmable. It’s integrated into both my 120 and 12 V systems, and hidden/tucked behind cabinetry, so replacing it would be extremely expensive and time-consuming.. I’d rather not replace it at this time since I will be rarely using it (mostly to help pre-chill the fridge before trips).
I will primarily charge off of roof mounted solar with an MPPT controller that is fully programmable.
Comparing charging parameters comparing Iota to Epoch I found the following:
Bulk Charging:
Absorption:
Float:
I understand using my existing Iota DLS-30 IQ4 charger/converter may not be produce the most optimal charge, but will using it occasionally (and briefly) be detrimental to my battery?"
The response I got from Epoch was as follows:
"It is not recommended to use this charger to charge our batteries. If you chose to do so, you will use at your own risk and could lead to a potential voided warranty on the battery. Our battery is a high quality product but as with any product not everything is going to be compatible. This is why we suggested a Lithium compatible charger so that you would have no damage to your battery."
Just looking for feedback from this group. Will I really damage my battery with the Iota? I understand the charge parameters aren't ideal, but it seems like they are close enough and the batteries BMS system should provide adequate protection? I haven't plugged into shore power yet, and don't really plan on using it to "charge" the battery, but would like to use it to pre-chill the fridge before going on trips and maybe using shore power for the 120v outlets inside the camper from time to time (though I can't really think what I'll use them for).
Future plans are to upgrade the solar panel (thinking 200-250w) since the 160w overland solar panel is underperforming, add a Victron Orion XS DC to DC charger, and add an inverter (thinking 1000 - 2000w). At which point I'll ad some bus bars, fuses, and clean up the wiring shown below.
Sorry for the long-winded post, and I appreciate anyone willing to provide some feedback. Attached some pictures for those that are interested.
"Good Morning,
Bulk Charging:
- Iota: 14.6V (for ~4hrs or high trigger of 14.6v to put it into absorption)
- Epoch: 14.2-14.6V
Absorption:
- Iota: 14.2V (for ~8hrs)
- Epoch: No Info
Float:
- Iota: 13.6V (~7 days or a low trigger of 12.8v to cycle back to bulk and start the process over).
- Epoch: 13.4-13.8v
