My take is that for the typical 3 sources - solar charger, AC powered converter/chargers (most factory systems are constant voltage) and the truck charging on our systems, it is of no concern.
There are only 1 or 2 on at a time normally, solar being on always in daytime. The truck is on relatively small percentage of the time. The solar chargers often have maintenance modes or multiple states based on voltage and time rules.
The truck and AC powered factory converter will more or less operate at a single maximum voltage. Each will have its own unique backoff/turnoff voltage setpoint, so one will give up before the other and when both are happy, all charging will diminish or cease. They also put out a lot of current so will blast away until the voltage comes up. They will dominate over the solar most of the time they are on.
The 3 and 4 state chargers, like a solar is likely to be, or in my case the add-on 4 state charger option on my AC converter, can be fooled and mess up it's idea of what it needs to do, but I doubt it is of concern over the long run. In the winter the solar output is often so low that the AC converter output will govern the state of charge.
The one that has the highest tunroff setpoint will rule. The one that has the highest charge current to offer below the lowest setpoint of all charge sources will rule. Other sources will chip in or just watch as they are likely to be fooled into thinking the battery is fully charged seeing a high voltage.
Long term, if the multiple sources were all running a long percentage of time, the desulfurization and 7 day charge modes if you have them will probably be ineffective or less effective.
I only use the AC in the winter when solar is useless and the truck is off. When the truck is on the AC is off. So the only time I really have 2 sources charging is summer with the truck running, and that is not very long to be of concern. See, it is simple
My suspicions are they same as yours. However, this does create a bit of a problem. If I've been stationary for 2 or 3 days and the battery is low, when I hit the road, the truck's alternator is only going to put 14 VDC. That's its cutoff voltage. The solar panel will be putting out 14.5, tricking the truck into thinking the battery is charged. So driving all day is going to result in no charge from the truck, just the 5.5 Ah (maximum!) from the solar panel. At the end of the day, my batteries will have very little charge compared to what the truck would have contributed if it didn't think the battery was fully charged.
