A couple of weekends back we were headed down a fairly well graded gravel road. A noise similar to that annoying sound of an aluminum can being squeezed over and over again caught our attention. We determined it was coming from the camper. With me in the camper while my wife drove, I was able to locate the noise. The siding on the font of the camper below the window, the section that faces the front of the truck bed, was slightly warped or bowed. As the camper flexed, the siding would make popping sounds.
Today I pulled the camper off and removed the front siding. I can find no frame damage or any reason why the siding would do this. So I intend to put it back together with some changes but want to get input from others as to good idea/bad idea or other suggestions before I do.
The siding is simply stapled along the outside edges and then the corner trim is screwed on over that. I intend to run beads of a epoxy along all of the frame pieces before I re-attach the siding. My thought being this will give the siding some support in the middle and not just on the outside. I also am considering adding a few screws along the frame pieces in case the epoxy doesn't hold. My only concern about adding the screws is wondering if that would inhibit some of the designed flexibility of the camper. Any thoughts, comments, suggestions will be appreciated. Ted
