fordjunky
I have an older Fleet I am starting to refurbish for a mobile winter powder chaser.
For load my use will be the following:
- I will be replacing all the lighting with LED
- I will need to add some type of water heater (I assume these are electric but have not got that far).
- I will run the propane furnace (igniter and blower use electricity)
- I might need to run some type of electric heater on the bed for really cold nights.
- I will use an electric water pump.
- Charge my cell phone.
Currently there are 2 wires bare wires on the outside of the camper that control all 12v in the camper.
I would like to update this system in few ways, but I am open if people have better ideas.
1 - Add 2 batteries in the camper that are charged off the truck as much as that can allow.
2 - Prep my new wiring solution for adding solar. At this point I don't think it makes sense for winter camping. Hopefully my camper is covered in snow every morning.
3 - Add a fuse panel not just a single inline glass fuse. Potentially redo the wiring so not everything is fed off 1 circuit.
4 - Put a connector on the camper to plug into the truck in some way.
Here are my questions:
- Will my F350 (dual alternators) be able to charge the batteries with the factory wiring? I have read both yes and no.
- Should I be looking at going with 6 volt batteries in series or 12 volt batteries in parallel?
- I like the idea of having a marine switch to isolate batteries if necessary.
- What does the wiring look like so that I can charge batteries by truck or solar and then run the camper. I would guess I need some type of controller but I am not really sure how that part works.
I have been able to find most of these topics in some form but nothing that talks about the entire system starting with nothing. Thanks for everyone's help.
