Land-roamer
I got new tires installed this week (Toyo M-55, range E obviously) and the tire tech pumped them up to 65 PSI front and 80 PSI rear, as per the specs on the label in the door jamb, for a fully-laden truck. Since my truck (3/4 ton with basically a 1 ton suspension) is not fully-loaded with the Alaskan on it, I have a feeling that 80 PSI may be too much pressure, and could lead to tire wear.
So: what kind of tire pressure do you use in your trucks carrying an Alaskan? My truck is a 96 Dodge Cummins, so I think that 65 is good for the heavy front. It's the back I'm not entirely sure about. A couple of people elsewhere have suggested that 65 would be a good pressure to run with in the back too, but I'm just curious as to what people are using here.
Thanks.
Thanks.
