I'll expand on this later but here's the basic info since this comes up a lot:
The resolution of photos straight out of any kind of camera is usually too large to post in most web applications. Most photo album software has an option to "export" photos at smaller dimensions so you can export your photos at say 800 pixels wide and you should be able to upload them fine. You can also use and kind of image editing software to reduce the photo dimensions or even some online tools like this one:
http://www.resize2mail.com/
More*************
Avoid reducing the image quality substantially to get the file size down rather than reducing the image dimensions. So if the upload does work the photo isnt going to look so great. Images in the gallery are resized to a maximum dimension 900 pixels. Images straight out of camers can be over 5000 pixels wide. The thing to do is to resize your images before you upload them rather than to reduce the quality.
Do you use some kind of photo album software to store and organize your photos? If so, it probably has an option of "exporting" your photos one or many at a time at a reduced dimension. If you can specify an exact dimension then export them all at 900 and they will upload easily. If the export feature gives you preset dimensions to choose from, choose the one that is larger than, but close to 900, and the photos will still upload and resize fine. 1260 pixels is often a preset in these programs.
If you do not use some kind of photo album software to organize your photos - you should start! Makes life much easier.
More*************
