markturnip
- Joined
- Feb 1, 2023
- Posts
- 13
Apologies if this isn't the right place to ask, but I thought there might be another FWC owner with a similar setup...
I own a 2010 Eagle FWC with an upgraded 140AH LiFePO4 Lithium battery running through the factory-installed IOTA IDP-30.
I'm using a Starlink Mini (the latest version) over USB-C, and it runs perfectly fine.
However, when I charge my 16-inch MacBook Pro, it struggles to deliver enough power. The charging seems to turn on and off intermittently, and it doesn't manage to charge my computer at all.
I also run a Bushman caravan fridge, which averages about 1.0 Amp/hr. Occasionally, I use the 12v vent fan as well.
I’m charging my MacBook through this station: link.
I’ve been advised to use a sine wave inverter, but I’d rather not, as it seems inefficient to step up to 230/240v and then use a transformer to step it down to 15/20v.
Fridge details: link.
