WarpathEngineering
- Joined
- Oct 14, 2006
- Messages
- 101
Ben & Marty,
Thanks for all the advice you've passed on to all of us, I'm sure everyone would agree, it has been very helpful!
In one of the previous posts we were talking about camper heights (Ford Super Duties vs other trucks) and it got me thinking of cutting my camper down to were it should be for my truck. Since I already have half of the interior removed, I got looking at the framework from the inside and I can see where FWC had added the additional height over the window. So my questions are:
Is there a reason why the tubing used for the framework is only welded on the outside? Is this to allow for flex or simply a time/money saving thing?
Is the siding installed with staples, screws, adhesive, or a combination?
If I cut the top down the height of the spacers, 3.25" which will give me 4" above the cab, I'll need to replace the section of siding just below the belt line. I've been looking for siding on the web and it appears that there are several types out there. Do you know what style FWC used? Could you suggest a supplier?
If the siding where to give me a problem and I found it worth my while to re-side the camper, would installing sheet aluminum like the newer style RV's are using cause a problem in your opinion? This would naturally be welded from the inside to the framework.
I'd also have to cut down my door or find a replacement. Would it be best to go back to FWC for a replacement door or do you know if I could go straight to the manufacturer? Who is the manufacturer?
While I'm in to it, are there any aspects of the framework that you feel needs to be improved upon? Reinforcement?
Where can I come up with replacement head liner material? Mine is in a bad way.
Although I do not think that "chopping the top" on the camper would be very difficult, (I've done it before on cars) there is another option. That would be adding depth to the overhang and increasing the room for a thicker mattress.
Would you find anything structrually wrong with adding to the depth of the overhang? The structure of the overhang apears to be nothing more than a 6" C-channel with a returned edge on the top. It runs from the rear wall of the camper around the front and I assume to the other rear wall forming a "belt". I am thinking of welding a like member to the underneath of this belt starting at the front camper wall around the front and back to the front camper wall on the other side. Then cutting down the front camper wall the install the overhang floor panel thus lowering the bedding area in the process. This would allow me to add almost 4" in depth to the bedding area. This would add greatly to the comfort of my wife, be the most cost effective, less time consuming change.
It will not however fully satisfy the real reason for taking the knife to the camper, lowering wind resistance. When driving my camper on the expressway you can feel the wind buffeting under the overhang. In the earlier post I mentioned to Ted about adding a faring under the overhang to help re-distribute the wind but since I have the camper apart, now seems to be the perfect time to make a change. Lowering the overhang to where it would have been for my truck not only adds a better visual picture but will help with the wind.
I know that this may sound like a lot of work but, like any man, I need a project to think about. Besides, I got a good deal on this camper and even with the changes, the cost still would not come close to the cost of a new one. May be some day!
