Screen Door Question from Jay?
marty
A Great Guy
Oct 3, 2006
338
Sacramento, California
Jay,
I believe you asked about fitting a screen door on your camper. If it was someone else, I apologize for the name mix up, I lost the post somehow.
You can take out the current door that you have and simply install the new door with screen in the same hole. They are the same size, just the screen door assembly has a deeper frame that the one you will take out.
The only trick to installing the new one is getting it to close properly. Most common problem is the top corner catching. Usually you can just file the corner down a little and this will fix it. If that doesn't work for you give us a call at 800-446-1003 and Jeff will be able to tell you how to adjust the door to make it work easily.
Ben
