Alley-Kat
Elder Statesman
As I have a solid rear window on my truck, i.e. thus no pass thru to the camper from the truck, I'm getting ready to make and mount a screen over the exterior of my front slider window on my ATC Bobcat shell. That window is great for getting fresh air into the camper and it's also very secure, so I can leave it open when I'm away from the truck. I just want to keep the bugs out.
Anyone put a screen on the exterior of the front window before?
Seems easy enough to make one for about $15 in materials.
Two possible sizes to make it...
I) Small, to fit inside the aluminium window frame, but larger than the glass. Mounting options seem to be... 1) semi-permanent with silicon sealant, or 2) velcro strips. I don't think I want any screws into the window frame that holds the glass.
II) Larger than the window frame (outside of it, actually), with mounting... 1) via a screw or two on each side, thru the aluminium skin and into the aluminium camper frame around the window (seal the screw holes, of course), or 2) velcro strips.
I'm thinking that the screen will need to be removed to clean the screen and the glass of the window every now and then. Like when I take the camper off or just before I put it on the truck. I don't expect to be able to remove the screen when the camper is on the truck.
Any other mounting ideas or techniques? Or, a preference of one of my ideas?
Thanks in advance.
Thanks in advance.
