norcalhawk
Hello,
I want to install a solar panel onto my FWC 2012 Hawk: I have (the following standard options), the small 3-way frig, water heater, furnace, 2-80amp aux. batteries, propane, stove, water pump, 2 fantastic fans, switched to LED bulbs throughout camper including porch and awning lights. I tend to be frugal with my power needs while out camping on the road(s) less traveled, so no plugging in for me
) All this sits comfortably on my 2002 Tundra. My question is: can anyone suggest a reliable, well made (preferably USA made), type, watts...of panel and controller and cable size that works well with our pop-ups. What size cable, length of cable from the controller to batteries (shorter the better?) and where to place controller? Do I need a voltmeter to monitor the residual charge to the batteries? Anything else you folks out there can share would be appreciated.
I also want to replace that slap of concrete that sits on the bunk with a softer, more forgiving mattress. I hear good things about this Nymbus Qualux Ultra (Q41) mattress. I also heard that Memory Foam is not a good choice due to it freezing in freezing temperatures?
Thanks...
michael
Thanks...
michael
