JHanson
Longhorn, as Brian mentioned, we had FWC install two 100-watt Global Solar semi-rigid panels on our camper. We wanted the extra capacity to charge camera batteries and run our laptops for working in the field. FWC moved the roof vents on our camper to the center to accommodate the panels:
We're extremely happy with the system - plenty of power, essentially zero wind resistance, and just two holes through the roof. We also used the GS charge controller, which has been operating perfectly.
Solar power is frighteningly expensive to install, but it's a lifetime investment, so it's worth it to do it right the first time. For most applications I think a single 100-watt panel would be sufficient. I think the ultimate setup would be a single GS panel on the roof, plus a portable plug-in panel with a strut that would allow you to park in the shade and run a panel out into the sun (and would also allow you to exploit very early and late sunlight).
Here's a link to the writeup I did on Overland Tech and Travel:
Power for the JATAC
Power for the JATAC
