****SOLD**** - 2003 Toyota Tundra TRD 4.7l 4x4 & 2002 FWC Eagle
costman13
Mar 4, 2014
Posts
38
Selling my beloved Truck & Camper Combo.
This setup is turn key and ready to go. This rig will take you anywhere.
Asking $24,000 USD obo.
Located in Missoula, Montana.
I will be taking detailed photos / walkthrough videos of both the truck and camper tomorrow when the camper is back on the truck.
2003 Toyota Tundra TRD 4.7l v8 4x4 - 258,000 miles
Factory tow package
Factory LSD rear end
OME 2886 Coils & Nitro Charger Shocks (~2 inches of lift)
Rear 3 leaf AAL with Firestone airbags and daystar cradles - great for dialing in your load.
16x8 Method Race Wheels 701
BFG AT KO2 285/75R16 10 ply tires with full size spare under the bed in stock location. Tires less than 2 years old.
Front diff drop for better CV angle
Wired to the bed to charge camper battery with battery cut off switch, fuse and charge solenoid
I removed the rear seat and built a platform to better accommodate a dog kennel (also wired for a kennel fan). I have all factory hardware and seat / seatbelts included in sale, should you want to take it back to the original.
I have all service records since new.
Timing belt / components & water pump recently replaced by a local Toyota mechanic
New wheel bearings, lower control arms, upper control arms and ball joints within the last few years.
Battery is less than a year old
New O2 sensors
All maintenance items are current
I wouldn't hesitate to drive this truck anywhere!
2002 Four Wheel Camper Eagle
Propex HS2000 propane furnace
Dometic 3 way refrigerator
Suburban 2 burner stove
Sink w/ hand pump
Lagun table
Fantastic 3 speed fan
100ah AGM battery
100watt Solar Panel
Renogy 50a DC/DC charge controller w/ bluetooth monitoring via phone app
Mule Expedition outfitters awning brackets
Aluminum scissor steps
Leveling blocks
Manual lift jacks w/ extension plates for install / removal
Camper dolly if you want it.
I rebuilt the bench seat to replace a homemade side dinette that the previous owner had built. This allows for significantly more storage under the bench and is still wide enough to sleep on without a rollover.
The roof was completely resealed a few years ago which included pulling all roof trim and screws and replacing butyl tape, screws and sealed with 3M sealant.
Rear lift panel was rebuilt with marine grade plywood and is in like new condition. Front lift panel shows no damage.
Upgraded camper tie down points with 1/4" aluminum backing plates and grade 8 hardware.
I have ordered a new horizontal propane tank to replace the leaking original.
This camper has been garage kept while off the truck during the winter months.
Selling as package deal only.
Interior
Exterior
Such a killer combo! Good luck with sale! Altho, if you change your mind, that camper would go great on my phantom gray '06 Double Cab Tundra!
I’m trying my hardest to keep the combo together!
Looking for something a bit larger and hard sided this time around.
Maybe a trailer of some kind? We’re not sure yet.
