SOLD: 2015 Four Wheel Camper Fleet Front Dinette
fwctaco
Aug 6, 2017
Posts
39
San Jose, CA
SOLD
This camper has been fully optimized for off-grid overland travel and is 100% ready for adventure.
Asking $17,000
Standard Options:
  • White aluminum exterior
  • Roof vent with fantastic fan over living area, extra roof vent over bed
  • Standard sink/stove combo
  • Dark blue cushion fabric
  • Standard propane heater
  • 4 Reico Mechanical Jacks with 2 manual cranks and 1 drill attachment
  • 2nd/3rd Gen Tacoma mounting brackets and custom rubber bed mats included
  • Standard factory aluminum turnbuckles included
  • Buyer will need to either have a wiring harness professionally installed or DIY to connect the camper to truck battery
Modifications:
  • Upgraded Electrical System (a similar system would run you $6-8K installed):
    200AH LifeBlue Lithium Ion (LiFEPO4) Battery
    Approx 4x the capacity of the factory AGM battery, lighter weight, and 4x lifespan. This battery will likely last longer than the camper.
  • Includes Bluetooth battery monitor
200W of low-profile, roof-mounted solar panels
  • Premium Lensun flexible aluminum panels glued to roof
  • Additional portable panel may be added using the factory connector on the back of the camper
1000W Xantrex Freedom XC Inverter/Charger
  • Run 120V AC appliances up to 1000W off of the battery
  • Efficient 50A battery charging from shore power
Sterling Power BB1230 Smart Battery to Battery Charger
  • Efficient, safe, 4-stage charging from vehicle alternator
  • Customizable automatic relay connects/disconnects alternator from camper battery
Replaced factory 3-way fridge with Isotherm Cruise 65 12V DC Fridge
  • Fridge includes 120V AC controller, but it isn’t hooked up to power
Removed factory cassette toilet
  • Space inside camper where toilet was is now open storage
    See pictures for an example of how we used this space
External toilet service hatches were sealed with high quality, white aluminum panels, interior holes were left as they were
Water system optimized for off-grid/winter use
  • Added small, optional ½ gallon interior greywater system
    Greywater can be routed either inside to a ½ gallon tank under the sink or to the standard ⅝” fitting outside. Interior tank is small, but useful for cold winter camping or situations where draining your grey water outside is not acceptable.
City water hookup has been disconnected, but can be re-connected if desired.
Shurflo Everpure inline “under sink” water filter
  • Water in 20 gallon tank is pre-treated using bleach and the everpure filter removes particulates and bleach. This keeps the tank clean and your drinking water safe.
  • Flow rate of faucet is unaffected.
Storage Mods
  • Storage under passenger dinette seat has been converted to a lockbox with hinged door and key lock.
  • Bamboo storage box on countertop
  • 2 wall-mounted Tackle Webs mesh marine storage bags
Custom sewn thermal pack
Overhead lights converted to low wattage soft white LEDs
WeBoost 4G-M Cell Phone Booster with window mounted antenna
Indoor Temperature and Humidity Gauge, Outdoor Temperature Gauge
Lux GEO-WH Smart Thermostat
  • Turn heat on from the truck cab using WiFi (WiFi hotspot or other device needed)
  • Program heat to come on before your alarm in the morning
AT Overland Aluminum Jerry Can Holder and Jack Bracket with Red NATO can and non-carb spout
Screen Door screen replaced with No-See-Um Netting
Screen door cross bar added on screen door
Extras
  • 2 10lb propane tanks
  • 25ft Teknor Apex Zero-G ½” fresh-water hose
  • 8ft Grey water drain hose
  • 50ft 14/3 Cold Weather Extension Cord with Lighted End
  • On Stage Speaker stand that can be used to raise/lower the roof with a drill
  • Portable waterproof garbage can, hangable by strap and buckle or velcro
  • Delxo 2-step steel fold flat step ladder
  • 2 No-See-Um Screen Covers for rear turnbuckle doors
  • 2 2x USB charging inserts for the factory 12V “cigarette lighter” receptacles
  • 4 custom made 60lb lift struts - never installed, but planned to use them if I put a roof rack and box on top
Minor Issues
  • Very small tear in the corner of the interior ceiling liner. It was like this when I got it. Someone left something on the counter when they lowered the roof. I would not notice this if I wasn’t looking for it specifically.
  • Bubbling in vinyl floor near the door. Vinyl floor has started to separate in a couple small spots near the door. The edges are still fine, there are just a couple small spots you can feel in the middle of the floor.
  • Some “oil-canning” on the roof, which seems to be common with these newer seamless roofs
  • One of the interior ceiling trim pieces has a small abrasion in the outer layer and will swell/shrink with high/low humidity. It was like this when I got it. Pretty much a non-issue, and could be fixed with a new trim piece or sealing the abrasion.
Bump - lots of interest and a few offers, but no asking price offer yet.
This is a killer deal if you want to boondock or overland and will put the upgraded electrical system to use.
