SOLD - 2017 Four Wheel Camper FWC Hawk Shell with Side Dinette/Furnace/Stove/etc. in Bozeman, MT
Chadx
Apr 1, 2016
Posts
68
SW Montana
SOLD - 2017 Four Wheel Camper FWC Shell Pop-up slide-in pickup camper with Side Dinette, Furnace, stovetop, Fridge, solar, etc. Available immediately; avoid the current 23 week (nearly 6 month) order wait. Located in Bozeman, MT.
More photos in my ad on Craigs:
https://bozeman.craigslist.org/rvs/d/bozeman-2017-four-wheel-camper-fwc-hawk/7089881906.html
We purchased this new in 2017 and ordered to our spec. It is in excellent shape. We take great care of our things. Always stored inside garage/shop when not in use and with the camper top stored popped-up during the off season. We chose to start with the shell and order factory options to include side dinette, furnace, flush stovetop, etc. to keep the entire rig lighter, eliminate plumbing, and so we could add an Engel MT45 top load fridge/freezer. Top load fridges are far more efficient than a front load fridge. The extra platform underneath the fridge allows for storage and easier access. The fridge can still be opened with the camper top in the down position.
I chose to purchase and install an aftermarket solar setup rather than ordering solar from the FWC factory because I wanted to use better components. I added a Solar Cynergy 180 Watt 12V Monocrystalline Solar Panel, Deltec 100 Amp 100 millivolt current Shunt, 30 amp breakers, Bogart Engineering SC-2030 solar controller and Trimetric TM-2030-RV programmable battery monitor. In bulk charging mode, this setup will generate 7 to 8 amps per hour in summer's mid-day sun.
The two batteries used are Exide fp-agm24dp 75 Amp AGM for a total of 150 amps. I exchanged emails with a senior engineer at Exide battery to get the ideal Trimetric settings for Bulk, Absorption and Float charger programming. The solar typically has the battery replenished by mid-morning. Battery pack has never been below 70% State of Charge (SOC) and typically doesn't drop to below 85% SOC. A small battery tender keeps batteries floated at 100% in the off season. Camper has provision for connection to truck alternator and FWC installed that wiring on my pickup when the camper was purchased, but I leave the wires disconnected under the hood of the truck because because the solar charges so well. Good idea to have it wired and available for backup, though, so I left it.
The bed cushions have never been slept on and were stored in our second bedroom. We used a memory foam pad that we already had. Note: The light spot, on the bed cushion in the picture, was from sunlight during the photo; it's not a blemish. Camper has factory thermal pack to help with insulation (warm and cold) and furnace keeps it toasty warm in low temps. We've camped down to 19 degrees. The over-cab bed pulls out to king size so a couple can sleep front-to-back rather then side-to-side which avoids crawling over one another to get in and out of bed. Another benefit is being able to reach the furnace thermostat from bed.
This unit is the "Shell" model with factory add-ons such as side dinette, furnace, stove top, etc. It does not have a sink or water tank (so no need for winterization and no risk of freeze damage). We used portable water bottles/jugs which allowed us to scale what we brought depending on the trip length. There is an appropriately-sized floor cubby in the back if one chose to purchase and bring a portable toilet.
Items in this build are listed below (minus installation chargers).
Below prices are pulled directly from the "Build It" section of the FWC website:
$12,995 Hawk Shell
- Mesa Exterior Siding in “White” (Standard)
- Large Passenger Side Window
- LED Interior Lights & Exterior Porch Light
- 12 Volt Outlet & USB Ports
- Privacy Curtains
- Screen Door
- New-style 1 piece aluminum roof
- New-style rounded rear door
$150 Aluminum Jack Brackets (Upgrade over painted steel)
$720 Mechanical Camper Jacks (4 corner)
$440 Yakima Tracks (Tracks Only) Factory Installed on Roof
$200 Extra Roof Vent
$300 Power Roof Vent Fan (Fan-Tastic Vent Fan)
$450 2nd 12 Volt Deep Cycle Battery (for dual 75amp batteries)
$450 Silver Spur Interior w/ Dovetail Greystone Fabric
$525 Flush Mount Propane Stove
$1,495 Furnace System with two 10 lb Propane Tanks
$2,195 Side Dinette Seating w/ Swivel Table
$495 King Bed Slide-out for the Cabover Bed
$750 Thermal Pack
$1,000 180 watt solar panel/Bogart Engineering SC-2030 controller/shunts/wiring/Trimetric TM-2030-RV monitor
$900 Engel MT45 top load refrigerator
$100 Fridge platform
$23,165.00 Total cost
SOLD - Selling for $20,000 cash (firm). Non-smoking/non-pet household. Ready for immediate pick up. FWC office confirmed that the current wait time is over 23 weeks so a new order would arrive around the end of August. I may be able to remove some accessories (Engel fridge, etc.) to lower the price. Thanks for looking.
More images...
