h2opup
For Sale: 2024 ATC Ocelot fits full-sized trucks with 6.5’ bed. Like New! Asking $21,950
Like new All Terrain Camper (ATC) Ocelot. I took delivery of this camper new in Oct 2024 and have used it only a couple of nights. It is stored under cover and is in perfect condition. These are wonderful, well-built & very comfortable campers. Turns out, it is just way more than I need or can deal with on my own, so I am selling it while still like-new.
This camper has a standard-sized main bed over the cab with a clean, plush covered 4” thick foam mattress. A reversible roof Power Vent is located over the front bed. The couch folds down into a second bed which is handy for stealth-camping if you don’t want to raise the pop-top. It has a 150-watt solar panel on the roof. The marine deep-cycle battery and solar panel controller are secured beneath the front of the couch, leaving a nice large storage space beneath the rest of the couch. There is also a small storage cabinet on the passenger’s side wall.
Along the driver’s side is a counter-top with a built-in 2-burner Dometic propane stove and a stainless-steel sink. A 12-volt pump provides the faucet with water from the built-in 15-gallon freshwater tank. There is a large cabinet for a fridge, and two additional cabinets below the sink and stove.
The camper comes with a 20lb propane tank with gauge that stores in an outside cubby. A highly efficient Dometic propane furnace heats the camper up fast. A programmable thermostat ensures that the camper can be kept at a comfortable temperature throughout the night.
The stowable table was custom-made in a smaller size (24”x18” same size as ATC’s Marty’s personal camper table) providing more room to move around when the table is being used – perfect for one person or for snacks. There is one 12-volt plug and 2 USB plugs below the countertop near the sink. A 2nd 12-volt plug is located beneath the front (cab) end of the couch which is perfect for a plug-in portable refrigerator or other 12-volt charging appliance or tools.
There is a large front cab window, a window in the back door, and a 50/50 slider window with screen on the passenger’s side. Two mounted LED outdoor lights (one on the back, one “awning light” on the passenger’s side) provide just enough useful illumination for entering/exiting the camper and moving around your vehicle at night. Camper comes with the standard dark curtains on all windows, a fire extinguisher, and a smoke alarm.
Includes 4 corner jack brackets and a set of 4 mechanical jacks. It also comes with the full cold-weather extra-liner insulation pack. Full-length Yakima tracks are mounted on the roof. There are 4 rear wall steps. A wooden support for a Roto-pax was built into the driver’s side back wall at the time of build. There is no Roto-pax presently, but the support allows one to be safely and easily added, if desired.
This new 2024 model sports a rounded-top lockable door and screen door along with light-colored countertops and interior walls. There is a high-quality vinyl floor over which I have placed a custom-cut BedRug that is cozy for bare feet (not glued down – easy to take out, if desired).
Standard Features (from the ATC website):
Standard features include a stainless-steel sink with 12-volt pump, 2-burner stove, portable table, a lower couch that makes into a bed, and plenty of storage room in cabinets, and under the couch. A 20-pound propane tank with gauge, a 15-gallon water tank w/monitor panel, 4 corners Jack brackets, Roof Struts, Pre-wired for Solar Panel,
*Marine/RV Deep-Cycle battery, a screen door with a deadbolt, and a front picture window.
*Our standard bed extends 48" over your cab and has a very comfortable 4" thick mattress. The bed's overall size varies with the model.
*Every camper is built with an aluminum frame that is made to flex with your truck bed without coming apart as most camper frames do over time.
*Sink
*Hand and 12volt pumps
*Stove
*Couch
*Table
*Monitor panel
*12-volt outlet w/USB
*Inside and Porch LED lights
*LED Marker and Brake lights
*Large passenger side window
*Front picture window
*Screen Door
*Curtains
*Fire Extinguisher
*Overhead storage
*5-gallon propane tank
*15-gallon water tank
*Drawer in cabinet
*Roof vent
*Roof Struts
*4 Corner Jack Brackets
*Pre-Wired for Solar Panel
*Marine/RV Deep Cycle Battery
*CO and LP monitor Alarm
*A generous amount of storage space in the cabinets and under the couch.
In addition to all of the standard features listed above, this camper includes the following options:
**Power Roof Vent / Reversible. Located over the main sleeping area.
**Dometic Automatic Forced Air Furnace – 12,000 BTU
**Mechanical Jacks – Set of 4
**Awning Light on Passenger Side (outside)
**Cold Weather Pack – Extra Liner Insulation
**2nd 12 Volt Accessory Plug w/USB located under couch near front of camper
**Rear Wall Steps
**Solar Panel – 150-Watt w/Controller
**Yakima Roof Tracks – Full Length
**Roto-pax support was built into the back wall (for adding a Roto-pax later, if desired)
Purchased new in October 2024 for $23,635 (plus $845 for delivery to Oregon and installation).
Asking $21,950 for this like-new unit. Located in Florence, Oregon.
Please PM me through WTW (preferred) or e-mail: waterpup34@yahoo.com
Thank you for your interest!
Please Note: I am requesting that the sale transaction / money transfer take place in person at a physical bank via certified check or other secure form of payment prior to taking possession of the camper. Thanks for your understanding.
*Sink
*Stove
*Couch
*Table
*Monitor panel
*Screen Door
*Curtains
*Fire Extinguisher
*Overhead storage
*Drawer in cabinet
*Roof vent
*Roof Struts
**Rear Wall Steps
