Any recommendations to quiet squeaky entry door hinges? Oil, grease? The hinge halves are aluminum and there are nylon/delrin washers or bushings along the hinge line to separate the two halves.
I don't know if my issue was the same as yours, but my squeaky door was fixed when I power washed all the fine dust out of the hinges.
Looking forward to hearing other's answers.
I used some firearm CLP (Clean, Lubricate, Protect) and it seems to have done the trick. The door and the screen door are integrated into the same hinges. The squeaking was coming from the screen door component of the hinges.
I have a small bottle of Lock-Ease graphite lock fluid that I use on all of my locks. It works wonders and also is fantastic on hinges. You can pick it up at any Ace Hardware.
