SUSPA bracket question
Jamesiam
Nov 1, 2010
237
Stateline Nevada
Howdy all,
I am planning on doing the SUSPA install. I will place the two front springs on the inside near bed and the rear springs on the outside.
All 4 springs will be part # C16-10198
The two brackets for the inside will be P67-00203, I can mentally picture how to place brackets to work.
What I cant imagine are these brackets being on the rear of the camper and on the outside, or will I need to purchase 4, 10mm ball studs for outside support?
Thank you
Here are some sample pictures on how we have done it in the past.
Not all campers are the same, so I can't say that these pictures are totally accurate for your application.
But it should give you some ideas on how things are supposed to work.
Hope this helps.
Happy Camping !
Stan
Thanks Stan, looks like I found the brackets I was looking for P67-00205
I am however re-thinking my mounting options on the inside, looks like you guys went a bit more heavy duty on the install with those small plates.
If you never plan on an awning, this is a easy to install way. These outside Ebay struts have been working fine.
http://www.wanderthewest.com/forum/index.php?/topic/4825/
Keith
