SUSPA Lift Strut and Bracket Part Numbers
SLOJET
May 9, 2010
Posts
92
San Luis Obispo, CA
Screen Shot 2013-06-01 at 3.56.15 PM.pngI spent a few hours last night trying to ferret out all the information posted over the years on lift struts. I wanted to post the part numbers and places to purchase separately from those threads in order to consolidate the information. Hopefully this saves somebody time.
These are the 40lb struts and exterior mount brackets for the hawk. Of course you may want stronger struts with a big load on the roof.
DaveView attachment 16545
SUSPA C16-15952
GAS SPRING PROP STRUT SHOCKS - $59.99 Shipped
Sold on Ebay by gotcha-trucks
http://stores.ebay.com/Gotcha-Trucks?_trksid=p2047675.l2563
  • 36" 40LB GAS PROP s
  • A pair (2) of SUSPA C16-15952 with 3 years warranty
  • Specs- Extended Length 35.43" Center Eyes of ball sockets
  • Compressed length 19.69" Center Eyes of ball sockets
  • Force 40 lbs
  • Ball Sockets 10mm
RV Nitro-Prop Lift OFF SET Gas Strut Shock Spring 10mm Ball Bracket Plate Mount - $2.99
Sold on ebay by RV-Trader
http://stores.ebay.com/rv-trader?_trksid=p2047675.l2563
My vote goes to Mcmaster-Carr as I could order just about everything I needed from them. I documented what I used in the roof lifter thingy thread.
The ones that are on my 2013 Hawk, factory installed are:
C16-10944. They are 80lb 36" extended. I'm thinking of going with the 100lb 36" extended Supsa springs from this site:
http://www.siraweb.com/p/112/gas-prop-c16-15953
They are the exact same measurements as the 80lb factory installed shocks. Since I'm planning on adding another solar panel on top, approx 20lbs, the stronger shocks should help.
Btw the website above sells everything needed to install the shocks inside your camper if you don't have them.
Anyone know the right shocks for the outside shorter roof (6 feet or less inside, not the new 6'4" height) on a smaller camper? I have a 2007 Falcon and the 35 inch suspas won't fit between the roof latches. Someone with a mid 2000's eagle maybe?
Thanks
