The Saints
Every time we use our water from inside the camper, we get this disgusting plastic taste. No matter what. We flushed the tank several times with bleach, taste get better stuff, etc. Then I decided to check on line about this and discovered I was not the only one. Only these wise guys said that they replaced their water hose. So I removed the front of my cabinet, lots of assorted screws, removed some wiring from my controls for the water pump, heater, lights and the front piece came off. I drained the water tank from outside, and took the hose ends off the faucet side and the pump. I pulled the hose out and now I get to replace it. Can you say Nalgene? I hope after all this that it works. I will up date when done.
